Frayed cable ends
Frayed cable ends
Postby mike.smith » Sat Mar 01, 2014 12:40 am
Any tricks for keeping cable ends from fraying? I have had to remove and reinstall the brake cables a couple of times, and it's always a real trick trying to get a frayed cable through the little hole in the cable fitting.
Re: Frayed cable ends
Postby Fastcapy » Sat Mar 01, 2014 1:43 am
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Postby radfordc » Sat Mar 01, 2014 10:33 am
For the small diameter brake cable the only way I've found to prevent fraying is to solder the cable before cutting. Make sure the cable is hot enough so that the solder wicks into the strands and then wipe away all the solder on the surface. When you cut the cable the ends should stay put.
radfordc
Postby GordonTurner » Sat Mar 01, 2014 3:49 pm
Brilliant Radford. Thanks
Gordon
Postby n502pd » Sat Mar 29, 2014 12:43 am
To get the solder to stick easier, and be 'sucked' into the inner strands, use a liberal ammount of plumbers flux. should be able to find it at a good hardware store. Also use a small propane torch, or at least a 200 watt solldering gun.. I have been doing this very thing for many years and if you cut the cable with sharp cutters about 1/2 in into the length of soldered cable, it will stay together.. Practice does help!!
Joe Nelsen
scratch built :D
Flying @81.7
KGYI/N. Tx Reg/Perrin Field
n502pd
Postby corton » Sat Mar 29, 2014 12:48 pm
Just to add to Joe's discussion, make sure the plumber's flux is NOT acid-based.
Of course, it's literally been 20 years since I've touched that type of flux, so there it may not be made anymore (the acid kind).
corton
Postby n502pd » Sun Mar 30, 2014 10:01 pm
Very good point!! I forgot that. I am pretty sure they make both kinds. I did look at my little tin of flux and it is about thirty years old! go figure!!
Joe Nelsen
scratch built :D
Flying @81.7
n502pd
Postby billmaxmcw » Wed Apr 23, 2014 12:05 pm
You can get crimp-type ends at bicycle stores; they use them for brake and shift cables.
Bill
Bill, Oregon
2012 Sonex taildragger (kit)
Aerovee 2.1, Aeroinjector
billmaxmcw
Postby tonyr » Wed Apr 23, 2014 11:15 pm
billmaxmcw wrote:You can get crimp-type ends at bicycle stores; they use them for brake and shift cables.
Bill
That would be ok to stop fraying, but I think the objective is to get them back through the swivel holes and no fraying.. ?
Sonex #813
First Flight... 4 Oct 14
298 hours having fun!
tonyr
Postby LLR » Mon Sep 15, 2014 10:03 am
This looks promising: http://www.eaavideo.org/channel.aspx?ch=ch_hints_general
~Larry
Sonex 1680
~Larry
N167JK
LLR
Users browsing this forum: Google Adsense [Bot] and 5 guests
