Removing flywheel
Removing flywheel
Postby mccool » Sun May 19, 2024 9:49 am
I have to pull the sump on my Gen2 3300, (don't ask!!), and to do that, I need to remove the flywheel! #@$%%**!
So far I've heated the bolts with a 1500W heat gun, protecting the magnets of course. All per the instructions, but can't get the bolts to budge.
Anyone else been successful with this, and how did you do it??
mccool
Re: Removing flywheel
Postby Kai » Sun May 19, 2024 11:51 am
What kind of heat gun is that- electrical?
Sorry, but that won´t do it. Those bolts are secured with Loctite 620, which needs something around 150 centigrades on the bolt heads to let go-maybe even more. This means concentrated heat on each bolt head from either a propane torch or better still an oxy-acy one for quite a while.
Make sure you throw away the old bolts after you´re done.
Sonex A #0525- SG, DS.
Kai
Postby snx590 » Sun Oct 13, 2024 11:35 am
Hi Ace,
Did you get the flywheel removed? What serial number do you have? There was a point where the sump could be removed without removing the backplate (those bolts were eliminated). Not sure what serial for the 3300 that happened.
What is your current engine status? I see you've had some work done this year at Arion.
I'm removing con rods in my #1574 (case not split - new Jabiru piston pins are too tight in my original rods). 550F on my Steinel heat gun with the 07062 reduction nozzle to focus the airflow did the trick with the 620 on the con rod bolts (yes...very unconventional...). I'm hoping to get everything off without dropping something in the sump.... (ok so far).
Terry
Sonex #590, J3300
snx590
Return to Jabiru
Users browsing this forum: No registered users and 20 guests
