BRS wrote:Saftey wire pliers are nice to have in the shop but for field repair the multitool will do the job.
a Spring torque wrench and sockets are heavy. Try to figure out what sizes you need and see if you can't get away with a 1/4" driver. There are some great little adapters that take little space, example (https://www.harborfreight.com/38-in-drive-59-59-ft-lb-digital-torque-adapter-58705.html).
While the multi tool has a screw driver I'd for sure pack a dedicated small driver and some bits. I have one of these http://www.amazon.com/dp/B09T9SLHH8 (stainless version) and was useing it yesterday and marveling at how well it worked.
tie-wraps,
Cell phone charger pack for phone and or iPad. If you have the space and load, get one large enough to jump the plane.
sunscreen
Duct tape
Hand held radio
Bryan Cotton wrote:We keep one of these in the back of our A model Waiex:
https://www.harborfreight.com/solid-non ... 65565.html
Weighs little. We put it on the windshield when putting in Decalin & fuel. When you get a fuel splash it protects the windscreen.
I'd disagree with bringing something to jump the plane. I think if you need a jump it's time to stop, put it on charge, and figure out what is wrong. Plus not sure how you jump it, get the cowl on, then fly away. My electrical system has been pretty reliable, however I did have one voltage regulator fail. Then I had a couple of bad ones. The genuine John Deere one as I posted in the other thread is the way to go. Consider upgrading at some point!
Bring some clean rags (we use old socks) to clean the canopy, if required. Water will do if you need to get bug guts off. For regular cleaning I use Camco 210 cleaner:
https://www.amazon.com/gp/product/B00AWRFAHY
I used to use Plexus but it has gotten really expensive and I like the Camco stuff better.
Regarding the trickle charger - what kind of battery do you have? If it is an EarthX, make sure you have the recommended charger. Charging an EarthX with a lead-acid charger/maintainer is a bad idea. The avionics guys put one on my airplane when doing the transponder check and I got a battery fail light immediately. So if EarthX get an Optimate charger:
https://www.amazon.com/gp/product/B00AHG7O74
Hambone wrote:
The plane doesn't have a storage area behind the seats, but that is one mod I'd like to add when I get her home.
builderflyer wrote:Not a tool, and I believe someone else may have mentioned it, a list of other Sonex owners and contact info for those based anywhere near your planned route. Not that others wouldn't help you as well, if needed, but the specialized kinda help another Sonex owner could bring to your possible dilemma shouldn't be overlooked.
Art,,,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,,,Jabiru 3300 #261
What color?
