Skippydiesel wrote:Whatever happened to the Sonex / Rotax??? You know the one that flew at Oshkosh.
Rumer suggested it had engine cooling issues - if true, was this resolved & how?
Sonex factory focus seems to have shifted to the new high wing however if they haven't learned from the Osh Sonex, it will also have Rotax cooling issues.
WaiexB22 wrote:I heard through a few people at Oshkosh last year that that plane is owned by the EAA not sonex and it has been pickled and stored. I did hear there were some cooling issues but I don't know the specifics and the plane has flown. I firmly believe with some time and thought the side outlets with dual radiators are a great setup. Mike Arnold used a very similar setup on the record setting AR-5. Given this plane was built in a week for a show that has long come and gone, I suspect the time and effort to work through the cooling issues has not been a priority.
I decided to use a single belly radiator rather than dual because of this plane and my discussions with sonex and Casey at OSH last year. Also, if I need more core area I can have a new one made and swap a belly radiator easier. I don't know enough about the one week wonder plane, but I did look at the layout very carefully when I was laying out m FWF. I think the issue is more about the radiator core area and orientation of the inlet to the radiator rather than it is about this side outlets, but again I don't know enough to confirm.
13brv3 wrote:They had ECU problems that held them up from what Mark said previously. It's too bad that EAA doesn't seem to have any interest in the project. Maybe they should sell it to someone who will get it worked out.
Users browsing this forum: No registered users and 31 guests
