Onex107 wrote:The 80 psi leak down test will pinpoint a leaking valve.
BobDz wrote:So....
High EGT can be caused by an excessively rich mixture. Fuel is still being burned when the exhaust valve is open. This scenario might also show lower CHT. But I am at a loss to explain why it would only be happening in one cylinder, and why it would just start randomly. Is the exhaust valve staying open longer than it should be? Maybe stuck slightly open?
Bryan Cotton wrote:BobDz wrote:So....
Bob,
When I enrichen the mixture the high EGT comes down, but the engine starts running poorly. So it seems the one cylinder is lean.
BobDz wrote:And your compression tests don't show a stuck / open valve.
Users browsing this forum: Bing [Bot] and 23 guests
