Onex Toe Brakes
Onex Toe Brakes
Postby Wanttobuild25 » Wed Mar 20, 2024 11:19 pm
I just purchased a Onex that will be converted to toe brakes. I’ve seen some photos depicting the conversion and am wondering if any detail drawings/part numbers are available anywhere.
Thanks for any input!
Jeff Ackland
Wanttobuild25
Re: Onex Toe Brakes
Postby gcm52 » Sun Mar 24, 2024 10:51 am
Attached is a drawing i used to fabricate toe brakes for my Onex. I got them from another Onex builder, Mike Turrell. The toe brakes worked great for both Mike and I. We both used the Matco MCMC-4 master cylinders with this setup
George Mueller
Onex Trigear
Rotax 912 ULS
gcm52
Re: Onex Toe Brakes
Postby Mike53 » Sun Mar 24, 2024 4:47 pm
It should be noted that I reworked the toe brakes so that the pivot was at the bottom of the toe brake where it encases the rudder . Pics can be found here.http://www.onexmike.org/hydraulic--toe-brakes.html. for the before and after. the improved geometry gives far higher psi leverage .
Mike
Antoine de Saint-Exupery
Mike53
Return to Onex
Users browsing this forum: Google [Bot] and 21 guests
