Corvair Engines - B Model
Re: Corvair Engines - B Model
Postby BobDz » Fri Mar 22, 2024 12:05 pm
GordonTurner wrote:Discussion of this on William Wynnes Corvair Facebook group:
https://www.facebook.com/groups/1117842 ... 7S9Ucbxw6v
Me too!
Just can't bring myself to go back on Facebook.
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Postby daleandee » Fri Mar 22, 2024 2:42 pm
SnakePilot wrote:Thanks, Gordon. Now... if I just had a FB account to fully take advantage of the WW site. Just too cantankerous to modernize!
I don't Fakebook either. There is a lot of Fly Corvair information via the Tube:
https://www.youtube.com/@WWFlycorvair/videos
And how about a Corvair powered twin ...
https://www.youtube.com/watch?v=GIMVkTk26fw
Postby lakespookie » Fri Mar 22, 2024 5:29 pm
SnakePilot wrote:Jill,
Did Bill give you an estimate of completed weight?
Most Corvairs are going to come in around 210 to 215 so you need to plan for that with a 3 blade prop its a little heavier than a 2 blade so those two things work against you and its why its not a factory supported engine. You could go with a 2 blade but its still going to be over weight and will be a bigger compromise in performance due to the limited prop clearance we get in these planes. I assume the torque curves on the corvair can make better use of the 3 blade to get better climb performance as a 3 blade produces more thrust for the same RPM, the trade off is efficiency due to the extra drag of the 3rd blade center section, A three blade should in theory also be smoother as the generated air pulse should be more consistent than a two blade, I wont say it will be quieter because the RPM range is still roughly in the same window so your blade speed should still match up and blade tip speed tends to be the biggest contributor to noise.
Jill's Build Log
PPL-ASEL
Tail = Complete
Wings = Complete
Waiex-B 0054
Panel G3X
lakespookie
Postby lakespookie » Fri Mar 22, 2024 6:39 pm
Here is a nice write up on corvairs from this year on kit planes https://www.kitplanes.com/corvair-2024- ... ers-guide/ it includes power cost and weight.
Jill's Build Log
PPL-ASEL
Tail = Complete
Wings = Complete
Waiex-B 0054
Panel G3X
lakespookie
Postby BobDz » Fri Mar 22, 2024 9:57 pm
Very cool builders log Jill.
I have to start watching the Saturday live stream.
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Postby SnakePilot » Fri Mar 22, 2024 11:29 pm
WOW,Jill!
That is a great article that gives lots of information and comparisons. Well done. Just what I needed. Thanks!
Waiex B Tail-dragger - 2850 Corvair Project
Coupe Top, Steam Gauges, Center Stick
Aluminum Main & Aux Tank
Fort Worth TX
N44YX (reserved)
SnakePilot
Postby SnakePilot » Sat Mar 23, 2024 4:20 pm
Dale, thanks for the links! I've got a few videos to watch! Happy flying.
Fort Worth TX
N44YX (reserved)
SnakePilot
Postby daleandee » Sat Mar 23, 2024 7:56 pm
SnakePilot wrote:Dale, thanks for the links! I've got a few videos to watch! Happy flying.
Here's a good video for understanding a lot about building your own from a core you find, assembling from an engine kit, or purchasing a full blown assembled engine.
https://www.youtube.com/watch?v=FykVa4pKlGg
BTW ... this appears to be a good deal on a 100hp Corvair on Barnstormers that was also mentioned on WW's Fakebook page:
https://www.barnstormers.com/classified ... rvair.html
FWIW,
Dale
3.0 Corvair/Tailwheel
Postby SnakePilot » Sat Mar 23, 2024 8:23 pm
Thanks for the links, Dale. I'll check them out.
Fort Worth TX
N44YX (reserved)
SnakePilot
Postby lakespookie » Mon Mar 25, 2024 4:44 pm
BobDz wrote:Very cool builders log Jill.
Feel free to hop in when every you see me online, It tends to be a later stream cause i am on the west coast but in general its nice to talk to folks show them what i am doing and always open to discussing tools techniques etc.
we are currently working on the control surfaces for the wings so its gotten a little less boring than the wings, that tended to be very repetitive and not great watching especially when you are deburing a gazilion holes lol.
But otherwise i try to make it entertaining and informative, i got a couple of avid aussies who watch 1-2 streams a month.
The only time i dont stream a build session on a Saturdays is if I am traveling or there is significant weather which is not typical for SD but has been happening a ton the last few weeks.
Jill's Build Log
PPL-ASEL
Tail = Complete
Wings = Complete
Waiex-B 0054
Panel G3X
lakespookie
Return to Other Engines
