by BobDz » Wed Mar 20, 2024 12:59 pm
Necessity is the mother of invention.
I have an Avery C Frame with a ram for riveting. I don't have a ram that is drilled for dimple dies, or other rivet sets. I have an email into Cleveland to see if their drilled ram will fit my 30+ year old Avery. But I'm tired of stopping work to wait for stuff. Patience is a virtue that I do not have.
So...
How to adapt my dimple dies to my Avery. My final idea was a concentrically drilled dowel. Inside diameter is 3/16 to accept the dies, out side diameter is the same as the diameter of the ram. Now, how to I make the connection? Turned out to be extremely easy! I used a short piece of heat shrink to attach the dowel to the dimple die (Just so you know the shaft of the dimple die is about 1/32 proud of the dowel. This way, no force is exerted on the dowel.). Then I used another piece of heat shrink to attach that "sub-assembly" to the ram. In theory the heat shrink will/should shrink concentrically, so that the dies line up.
Works PERFECTLY!!
- Attachments
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
