by BobDz » Tue Mar 19, 2024 2:01 pm
Has anyone removed the Lower Spar Channel (T12-04) from the vertical stabilizer and installed it on the aft fuselage first? There is a 4" access hole in the r/h side skin for access to the hardware. Just thinking it would be easier, and probably more accurate, to install it this way than to balance the entire vertical stabilizer for installation.
Kind of a solo builder issue.
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
