by BobDz » Sat Mar 09, 2024 8:59 pm
I've been experimenting with different ways to make using a scotch brite pad easier. I've found a keeper.
The sanding block in the picture I made in the mid 80's. Changed the 80 grit to a 4.5" x 5.5" scotch brite pad and it works great. Much easier to use. Much easier on the hands.
If anyone needs a sanding block sketch just let me know.
- Attachments
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
