BRS wrote:I have used Marine quality and feel the shrink tubing does a nice job holding the wire and keeping it from breaking at the terminal.
builderflyer wrote:I have a complete set of crimper tools for all types of connectors, only aircraft quality connectors. But after properly crimping a wire in a connector verified by a hard tug on the wire, it still can come loose sometime later. So now in addition to crimping, I solder all connections, even D-sub pins. With soldering though it's important that the wire(s) be supported not far from the connector to avoid a "fatigue" type failure of the wire where it meets the connector. For most connector types, I'll also install heat shrink tubing for insulation and support purposes. Overkill? Possibly, but I sleep better.
Art,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,Jabiru 3300 #261
BobDz wrote:
What defines "aircraft quality connector"? Is it the double crimp?
It's the 2-2.5X higher price! I've been guilty of using some cheap lugs and I've also had a couple of issues. Next Waiex that is one place that I'll not go cheap.
I worked at Sikorsky for many years and we pretty much always uses crimp connectors instead of solder, mainly for fatigue. So I avoid solder wherever I can, but really support it well if I need to solder.
Bryan Cotton wrote:I'd use aircraft quality terminals. I respect other views, but that is what I'd do.
Users browsing this forum: Google [Bot] and 18 guests
