Statis Ports
Statis Ports
Postby pilotyoung » Mon Feb 26, 2024 12:13 am
Has anyone put static ports on the sides of the fuselage on a Onex? If so how did it work? And if so, where did you put them?
Thanks.
pilotyoung
Re: Statis Ports
Postby Jim1342 » Tue Feb 27, 2024 12:30 am
Reinhard Metz did an article in Kitplanes a while back.
Static Port Location.doc
(2.09 MiB) Downloaded 273 times
Jim1342
Re: Statis Ports
Postby pilotyoung » Tue Feb 27, 2024 1:38 am
Thanks for your help.
pilotyoung
Re: Static Ports
Postby lgsievila » Tue Feb 27, 2024 7:45 am
When I installed my Dynon AOA pitot tube, I tried Dynon Static Ports a couple of different locations on the fuselage and nothing worked. Probably didn't get far enough aft. Ended up leaving the Sonex supplied pitot static tube under the wing and used the static portion only. So I have two things hanging on the bottom of my wing.
Loren Sievila
Conventional Gear Onex33
CAMit 2200
Dynon Skyview
lgsievila
Re: Statis Ports
Postby BobDz » Tue Feb 27, 2024 9:17 am
Jim1342 wrote:Reinhard Metz did an article in Kitplanes a while back.
Any chance you have this as a PDF?
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Re: Statis Ports
Postby pilotyoung » Tue Feb 27, 2024 11:27 am
Here it is.
Static Port Location-pdf.pdf
(2.48 MiB) Downloaded 244 times
pilotyoung
Re: Statis Ports
Postby BobDz » Tue Feb 27, 2024 1:06 pm
pilotyoung wrote:Here it is.
Thank you!!
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Re: Statis Ports
Postby Bryan Cotton » Tue Feb 27, 2024 3:14 pm
Very cool. Where is Graham when you need him?
Re: Statis Ports
Postby 13brv3 » Tue Feb 27, 2024 3:46 pm
Back when I was researching static ports, I read that article. I wasn't going to go though all the testing, so I took my best shot at locating it similar to where it was on the RVs I've built. I had previously tried it on the pitot/static tube, and open in the wing, and cockpit. This works at least as well as those, but at some point you lose the ability to really prove if it's exactly right. Obviously there's one on each side tied together. Bottom line, no guarantees on this location :-)
Rusty
Fixed wing, gyroplane, A&P
13brv3
Re: Statis Ports
Postby pilotyoung » Wed Feb 28, 2024 9:24 am
Thanks for showing the picture and telling your experience.
pilotyoung
