BobDz wrote:Bryan Cotton wrote:I had a piece of copper I was going to use, and that stuff is heavy! Aluminum has been good enough for me. Threads in aluminum can be sketchy so I use a nut on the back side.
I could easily use aluminum, and probably should. Afterall, if I used the airframe as ground it would obviously be aluminum.
Appreciate the comments. Helps to refine my project. And prevents tunnel vision.
daleandee wrote:BobDz wrote:Bryan Cotton wrote:I had a piece of copper I was going to use, and that stuff is heavy! Aluminum has been good enough for me. Threads in aluminum can be sketchy so I use a nut on the back side.
Nicely done and the more you develope it the better it gets.
FWIW I bought a grounding block from B&C Specialities (forrest of tabs) with 24 connections on it and found out that I needed more than that. Of course I have an electrically dependent airplane but I never imagined I'd need that many connections ...
Dale
3.0 Corvair/Tailwheel
Friesen5 wrote:I did something similar almost 20 years ago. It’s providing a solid ground for my Sonex. I took a photo of it yesterday, so I’ll try to attach it.
Mervin Friesen
Sonex 122
Bryan Cotton wrote:Looks good Mervin!
Like Dale, I find that too many ends up being not enough. Two lugs per screw is really just a serving suggestion.
3/8 is massive. I wouldn't go bigger than #10, but I would support both ends with that design. Or mount it in the middle possibly.
BobDz wrote:I originally used 3/8" because on the engine side of the firewall there will be two 2/0 cables attached and I have 2/0 x 3/8" lugs. I also have 2/0 × 5/16" lugs. So I will downsize to 5/16.
