Bryan Cotton wrote:Looks good! I'd recommend using lock nuts on the outsides.
lakespookie wrote:If you double up i would change the approach direction so the top comes in over the top and the bottom comes in from the bottom that will make it a little cleaner with double stacking.
Skippydiesel wrote:I apologise in advance for being "picky" -
First - Great idea! Probably don't need such a heavy bolt.
Why not use brass/copper through bolt & nuts, for least electrical resistance, minimised potential for electrolysis and I agree with Brian, use a lock nut for best anti vibration security.
Bryan Cotton wrote:I had a piece of copper I was going to use, and that stuff is heavy! Aluminum has been good enough for me. Threads in aluminum can be sketchy so I use a nut on the back side.
