by BobDz » Sun Feb 11, 2024 8:35 pm
One of the suggestions on the EAA online electrical workshop, is to have the breakers or fuses directly above the switch all in a nice row. One label on the panel works for both the switch AND breaker/fuse.
Because I can be a cheap SOB I'm favoring blade style auto fuses.
So I started checking out different products to make this work. And down the rabbit hole I go! Which seems to be my new hobby. Originally I found a fuse block with blown fuse indicators from the boating/camping world. Very nice. We used a similar type panel in my son's van build. The blown fuse indicator is a very nice feature. But the fuse block isn't really configured in a way that would look nice on an aircraft panel. Then I found individual fuse holders from NAPA that have a blown fuse indicator. Very cool, but stupid expensive - $16+ each. So deeper down the rabbit hole I go! A fuse holder, red LED, and a resistor for the indicator circuit only costs 90 cents. Add a toggle switch and I'm good. My son has a CNC router that we'll use to make an attractive sub panel. The entire switch/ fuse/ indicator panel should be quite afforable.
Problem solved ( I think).
Next step will be to make a mockup and see if I like it.(WHILE building a fuselage)
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
