by Scott Todd » Sat Feb 10, 2024 10:06 am
Try to be objective and look at things from an engineering perspective. First of all, aluminum airplanes are VERY fragile when loaded in directions they are not intended for. It doesn't take much to really wrinkle one with a simple ground touch. For example, the wing rib dent could almost happen from someone bumping into it on a walkaround. I've seen it happen. This airplane is not showing signs of significant damage. Contrary to urban legend, it wont just fly apart in the air because something is slightly bent. Of course it should be fixed but 'hidden' damage is really hard to miss on aluminum airplanes.
I must not be looking at the same pictures as everyone else. I don't see why the entire front end has to be re-built because a motor mount is bent. That those parts off and further inspect. I suspect the material around there is in good shape and a new angle bracket can be installed.
The gear leg may have been straightened. So what? Our airplanes are designed to fly, not crash. They are not tolerant of hard landings. Pound it and bend it. Get some proper training and learn how to land. My students don't pound airplanes. But many do...The quality of current flight instruction could be a new topic for another day.
The tip wing rib is nearly a non-issue. Look at the loads out there. Theoretically they go to zero at the tip. The tip is NOT supporting the entire weight of the airplane. removing the rib and bending it all back to original shape is probably fine. Again, NO loads out there.....
The upper machine screws were not pulled into the angle. The countersinks were deep. The loads required to deform the aluminum by 'pulling' a screw head into it are unimaginable. Unless the countersink was WAY too deep, stuff would bend and break before that deformation could be seen. Looking at the backside will tell but I suspect it wasn't 'pulled' in. Put one in a press and try it.
I've also worked on and flown Sonex's that were far more damaged than this one from hard landings and off-field landings. But I've also seen pilots that see a small dent in an airplane and deem it complete scrap and would NEVER get in it. Dale mentions to check the squareness. I think it would be pretty hard to knock one out of square without a lot more visible damage but its a good starting point.
Scott Todd on Sat Feb 10, 2024 10:29 am, edited 4 times in total.
