by Weatherpilot » Tue Feb 06, 2024 12:51 pm
Got a question. I'm installing an AV Map Ultra EFIS. To do that I need to move my MGL radio. Was going to just put the radio on the other side of the panel. Plenty of room there. However, the wiring harness won't reach. So I have a hole where the inclinometer was (don't need it anymore since the Ultra has one) but there is an issue with the bottom of the panel. Can I trim this piece that's in the way to make the MGL radio fit or will it violate the integrity of the instrument panel structure? Second picture is the hole. (BTW - some sloppy cutting there by someone else - Not my work) First is the installed EFIS and you can see the inclinometer I am removing.
- The EFIS Installed
- This is the hole. Want to cut out that lower piece.
- thehole.jpg (114.86 KiB) Viewed 1271 times
Greg Hubert
Sonex A #972 TD
Aerovee Prince P-Tip / Dual stick
Third Owner
Eastern Panhandle of West Virginia
