Engine Mount Rubbers
Rotax 912 series discussion.
Re: Engine Mount Rubbers
Postby Murray Parr » Tue Jan 09, 2024 4:33 pm
Hopefully you haven't put your order in yet. I would like to get a set of the -14's as well if you would like to go halves in the shipping.
Murray Parr
WXB0015
Rotax 912ULS
MGL Explorer Lite
First flight May 6/23
RV9 builder (Sold)
Murray Parr
Postby Skippydiesel » Wed Jan 10, 2024 6:37 am
Phone you tomorrow Murray.
Have local supplier, going to give me a quote on the 14's, when he gets back from annual holiday.
Skippydiesel
Postby Skippydiesel » Mon Jan 15, 2024 8:19 pm
1. "To try & preserve as much of the Sonex recommended system (22001-13) I will start by replacing the lower donuts with the 14 donuts and see if that has the desired effect."
As a first step, I think the above is small, therefor may not result in sufficient movement reduction, so planning for the future (if needed);
2. The lateral movement, viewed from the cockpit, is to the left. With this in mind, could step two be replacing the two - 13 mounts, on the left side only, with the stiffer -14's. What might be the negative effect of mixing two diffrent mount stiffness (Note: All 22001 mounts have the same dimensions)???
3. It seems that the rear/aft mounts are being subjected to more movement that the front two - Should I consider replacing the aft mounts with -14's leaving the front two -13's? As in 2, what might be the negative effects??
4. I will be purchasing 4 X - 14 mounts, so if step two/three don't have the desired effect OR are skipped (due to advice/reflection) I will just replace all -13's with -14'. Aside from checking for desired movement reduction, I would appreciate any advice on what I should monitor ??
Skippydiesel
Postby Skippydiesel » Thu Jan 18, 2024 5:13 am
So I now have the Hutchinson/Barry Controls 22001-14's fitted.
In my last post I had planned to substitute bits & pieces of - 14' s only going to fully replace the -13"s as required, however the suppliers of the mounts advised that I just replace the -13's completely. They seemed to know what they are talking about (30 years in the vibration control business) so went with their advice.
My Sonex is based on a grass strip, very wet at the moment, so no flying but hoping for hot dry weather over the next few days, to dry it out and then I will test/report back on the -14 mounts.
Skippydiesel
Postby Skippydiesel » Mon Jan 22, 2024 7:49 pm
I have just done 1.4 hrs (2 engine starts) with the new Barry 22001-14 mounts (with my Cupped Snub Washers) in place .
Did not notice any major change in vibration/noise - possible very small increase in HF vibration through control stick.
Significant improvement (reduction) in lateral movement but still just marking witness tabs.
Next step - add the Sonex supplied spacer washers ACV-P54 -06 & -07 .
Skippydiesel
Postby Skippydiesel » Sun Feb 04, 2024 7:18 pm
Have done 2.4 hrs with the new Sonex spacing washers (FYI: - they have a larger OD & are better machined, than the original supplied - they actually fit without further adjustment).
Again some improvement BUT still getting a touch, between rear right exhaust header and engine frame.
Options;
    Go another step stiffer with the Barry Controls engine mounts to part number 22001-15
OR
    Have the offending exhaust header reworked/new build, with slightly wider clearing curve - this last is possibly the best solution, as preserves the engine mount(s) vibration control while allowing damping movement BUT as is often the case, the most costly and time consuming
Skippydiesel
Postby Skippydiesel » Tue Feb 06, 2024 4:50 am
It has been suggested, on another Forum, that making a strategic dent/depression, in the existing & offending exhaust pipe, to enhance the clearance between it & the frame, would have little impact on the cross sectional area of the pipe and therefore be unlikly to result in any engine performance loss - what thinks the Brains Trust??
If you agree with this proposal - how would you go about it? eg would you heat the pipe to plastic stage & then press/hammer in the depression, fill the pipe with sand to reduce unwanted distortion, do the aforementioned cold, etc
Skippydiesel
I will need a dent of about 10 mm in depth (in a 25 mm pipe) to be assured of not contacting the frame, in a poorly executed engine stop.
Have a look at this automotive experiment, to assess the effects of denting the exhaust system:
https://www.facebook.com/watch/?v=152724102049876
Skippydiesel
Postby Skippydiesel » Wed Apr 17, 2024 9:01 pm
Update!
Finally bit the bullet and had my right rear exhaust header remade/adjusted, to give about 12mm extra clearance to the engine frame - seems to have done the trick. No evidence of brushing/touching in about 3 hrs of flying.
I have added one additional washer to the front two rubbers. This is to slightly change the prop thrust line, to reduce the amount of up elevator in cruise - seems to have worked. Carrying weight (max 18KG) in the luggage compartment behind the seat, has a similar effect.
Skippydiesel
Postby Skippydiesel » Sat Sep 14, 2024 10:16 pm
Follow Up!
So far so good - now at 108 hrs. No more contact between engine & frame/cowling.
Bit concerned about a carburettor float chamber fuel overflow, out of breather pipe - may be due to high frequency vibration "foaming" fuel. Exploring options/fixes.
Skippydiesel
Return to Rotax
Users browsing this forum: No registered users and 29 guests
