by WesRagle » Sun Feb 04, 2024 5:12 pm
Hi VillaAir,
My plans and plane are not here, but as I recall ...
There are some pre-punched holes in the leading edge of the wing skin that have no rib flange behind them. Also, there is another pre-punched hold, the aft hole, most outside, in the double row of rivets at the wing spar root that shouldn't be installed. That hole hits right on the edge of the spar cap where it tapers down.
YMMV,
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
