Oil pump cover seal
Oil pump cover seal
Postby Bryan Cotton » Sat Jan 27, 2024 11:54 am
When I got rid of my external filter, I put in a normal oil pump and I bought a Gene Berg 239 pressure relief cover. I've had lots of leakage from the pump since. Per the manual (IIRC) I put the cover onto the pump with no gasket, though there are gaskets for it. I am going to try adding the gasket. Wondering if anybody has experience or wisdom to share regarding sealing the oil pump.
Should I eliminate this leak, I am sure there are others to protect the belly of the airplane, so no worries there.
Re: Oil pump cover seal
Postby Bryan Cotton » Sat Jan 27, 2024 3:01 pm
I just had a discovery. My oil pump bolts were a touch long. I don't think I had good clamping on the pump and cover.
Postby Area 51% » Sat Jan 27, 2024 3:17 pm
Probably why the stock VW case comes with studs and nuts.
Area 51%
Postby Bryan Cotton » Sat Jan 27, 2024 3:31 pm
Area 51% wrote:Probably why the stock VW case comes with studs and nuts.
Yeah I can see that being better. I skipped the cover gasket and just used sealer. The original oil pump setup was fine. It had a thicker cover. Not sure how I missed that before.
Postby bvolcko38 » Mon Jan 29, 2024 10:12 am
Def need a gasket! 2 in fact! One for the pump one for the cover!
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Postby Bryan Cotton » Mon Jan 29, 2024 10:19 am
bvolcko38 wrote:Def need a gasket! 2 in fact! One for the pump one for the cover!
The Aerovee manual says no gasket under the cover. That worked for me before, so I'm trying it again with my shortened bolts. If it doesn't work I'll use the cover gasket.
Postby daleandee » Mon Jan 29, 2024 4:37 pm
Be certain the plate is flat. One trick is to use some fine emory cloth on a sheet of glass to polish the surface of the cover.
Dale
3.0 Corvair/Tailwheel
daleandee
Users browsing this forum: No registered users and 53 guests
