AeroConversions Throttle location
Postby rizzz » Tue Feb 18, 2014 8:13 pm
Whilst I’m waiting for the parts to fix my average wing rigging job I’ve started playing with the panel and instruments.
I installed the throttle last night.
I have an AeroConversion Throttle and I was trying to figure out where to install this in combination with the standard trim lever setup, people with a dial-a-trim system seem to just attach it to the aft vertical wing attach angle but when you have the standard trim lever between the forward and aft wing attach angles, the throttle sits too close to the trim leaver, at least in my view.
I could attach the throttle a bit higher above the trim lever so it sticks out just above the upper longeron, but when I sat in my airplane and tried out how this would feel it did not feel comfortable to me. I’m not the tallest person in the world, maybe others would feel more comfortable with this solution.
Surely others must have run into the same dilemma so I researched a bit on the net to see what my options are but I could not find much information on the subject so I had to come up with my own solution.
I decided to install the throttle slightly higher than the trim lever, still well below the upper longeron but move it back 2” behind the aft vertical wing attach angle, I did this using a piece of 1”x1”x.125” angle and a plate to attach the angle to the aft vertical wing attach angle.
The photos will probably explain in more detail what I’ve done:
Once installed sat in my airplane and I must say, this throttle position feels very comfortable to me. I will have an extra 3 rivets visible on the right forward fuselage side skin but I don’t believe that will be an eye sore at all.
Re: AeroConversions Throttle location
Postby mike.smith » Tue Feb 18, 2014 8:31 pm
rizzz wrote:Whilst I’m waiting for the parts to fix my average wing rigging job I’ve started playing with the panel and instruments.
Here is where mine is (I though I had better photos, but I guess not):
http://www.mykitlog.com/users/display_l ... 2038&row=6
http://www.mykitlog.com/users/display_l ... 158&row=45
Mixture is here with red knob:
http://www.mykitlog.com/users/display_l ... 244&row=44
It's very similar to the Citabria throttle location that I got my tailwheel endorsement on. I'm just over 6' tall with the lowered seat mod.
#439
Users browsing this forum: No registered users and 100 guests
