Aluminum Fuel Tank
Aluminum Fuel Tank
Postby BobDz » Sun Jan 14, 2024 10:25 am
Just curious if anyone has attempted to use an aluminum fuel tank?
It appears to me to be relatively easy to make. Either a welded assembly, or a riveted assembly with a tank sealer.
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Re: Aluminum Fuel Tank
Postby Bryan Cotton » Sun Jan 14, 2024 10:44 am
I know one was made down in Area 51. The cool thing was that it was lighter. I'd consider it if I built another. I've had no issues with my poly tank.
Postby BobDz » Sun Jan 14, 2024 10:51 am
Bryan Cotton wrote:I know one was made down in Area 51. The cool thing was that it was lighter. I'd consider it if I built another. I've had no issues with my poly tank.
Lighter was my motivation.
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Postby Area 51% » Sun Jan 14, 2024 11:20 am
The one I made was 3lbs lighter than the plastic job. It also holds another 3 gallons because I made it to fit under the glare shield better than the stock tank.
Never had a fitting pull loose either.
Postby BobDz » Sun Jan 14, 2024 11:26 am
Area 51% wrote:The one I made was 3lbs lighter than the plastic job. It also holds another 3 gallons because I made it to fit under the glare shield better than the stock tank.
Excellent! Thank you for the info.
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Postby kmacht » Sun Jan 14, 2024 4:17 pm
Just make sure you think through unintended consequences. An aluminum tank sitting right over your legs may not be the best idea in a crash. The plastic rotomolded tank is much more durable
#554
Postby Jgibson » Sun Jan 14, 2024 6:26 pm
kmacht wrote:Just make sure you think through unintended consequences. An aluminum tank sitting right over your legs may not be the best idea in a crash. The plastic rotomolded tank is much more durable
#554
You mean like the Ercoupe, or Luscombe with the aft fuse tank, or the many bi-planes build and designed with fuel tanks there? Any durability issues the rotomolded tank may have are negated by the possibility of a fitting being easier ripped out of those plastic threads.
Fuse tanks have been around since the beginning of flight. Is it the BEST place to put it, probably not but certainly not something that would prevent me from using an aluminum tank. Once it’s installed, forget about it as far as leaks go as opposed to the ‘plastic’ stock one that seems to constantly be plagued with leaking thread issues, stress issues from turning a valve on and off. And because of the location of the Sonex tank, the LAST thing anyone wants to do it remove a leaking tank. If the aluminum tank and bungs are welded correctly, and the mounting is done properly, install it and forget it.
And the Sonex can certainly use any additional fuel capacity obtainable.
Nice job on that welded tank!
Joe
Jgibson
Postby BobDz » Sun Jan 14, 2024 8:54 pm
There are plenty of examples of welded aluminum tanks.
And...
There are a few examples of riveted tanks with various forms of sealer. Afterall, Vans wing tanks aren't welded. And there are many suppliers of various tank fittings. I think I'm going to do it. Maybe 025 or 032, closed head countersunk rivets, and tank sealer.
Should be fun!
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Postby kmacht » Sun Jan 14, 2024 9:19 pm
It's experimental aircraft so it's up to you to choose. I just want to point out that the other planes mentioned that have aluminum fusealage tanks also don't have a better and safer option like the sonex does. .
Postby BobDz » Sun Jan 14, 2024 9:33 pm
kmacht wrote:It's experimental aircraft so it's up to you to choose. I just want to point out that the other planes mentioned that have aluminum fusealage tanks also don't have a better and safer option like the sonex does. .
Understood. But "better and safer" are subjective terms.
I'm not a fan of rotational poly tanks. We used two in our van build, and have replaced both. One of them will probably be replaced again. The weak link in the chain are the threads. Probably explains the use of oops fittings.
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Return to Sonex-B / Waiex-B
