Wire Routing...
Wire Routing...
Postby dboeshaar » Thu Dec 28, 2023 4:13 pm
Any pictures of how to route wiring from tail cone to instrument panel and the battery? Things like tail strobe, transponder antenna, remote radio gear, etc.
What did folks use for the wiring block? Where did you put it?
Once the glare shield is in, is EVERYTHING done on your back? Ouch!
Dkb
David Boeshaar
KWHP
TDAIRCRAFT.COM
My Greatest Fear: What if the Hokey Pokey really is what it's all about?
dboeshaar
Re: Wire Routing...
Postby Bryan Cotton » Thu Dec 28, 2023 5:16 pm
I don't have much in the tail. Just my pitot probe plumbing and coax for my VOR antenna. I used self- adhesive tie wrap points. They route through the tailcone and then along the rudder cables to the nose.
Leave the floor skins off as long as possible. Much easier to work from underneath. I did most of my wiring on the bench. My biggest regret is not figuring out a way to open up or hinge down the panel for maintenance.
I'm not sure what you mean by a wiring block.
Re: Wire Routing...
Postby daleandee » Thu Dec 28, 2023 5:29 pm
I have a Cleanex (Corvair powered taildragger) with the battery in the tail. I have a good bit of wiring from the rear to the front. I ran the wiring under the spar. You can get a glimpse of what I'm talking about at the 2:00 mark in this video:
https://www.youtube.com/watch?v=Hg0fgs4cFuE
Dale
3.0 Corvair/Tailwheel
Return to Sonex-B / Waiex-B
