Scott Todd wrote:Its pretty straight forward. Put a mark on the flywheel and case corresponding to 28 BTDC. The engine manual shows you how to locate this. I used a silver sharpie. I put mine around the 2 o'clock position looking in from the rear. I'll post a picture tomorrow when I pull the cowl for the oil change. Clamp the light to the battery and put it on #1 primary spark plug wire. I have done it several times in the past. I recently bought this one to do my Onex.
Once you get it working on the #1 Primary plug, shut it down and move it to the lower plug wire and try again. You should instantly see the secondary ignition mark. Anything above an idle is fine since its fixed timing. I usually go to around 1400 to not blast the person running the light. Once you get it set, you can try revving it up a bit but mine never moves.
WesRagle wrote:Hi Mike,
I probably shouldn't say anything since I don't have an AeroVee. But, I will say this: Some folks (Including Scott Casler of Hummel Engines) number the cylinders according to firing order. Looking from above and behind the engine that numbering is illustrated below.
Cyl3|||||||Cyl1
Cyl4|||||||Cyl2
Perhaps Scott Todd was using that numbering scheme.
I haven't tried the "timing light method" in many years but I'm about to. I would be interested in knowing if you get a good timing light trigger by clamping to the 12 V lead (power) of the ignition coil.
Good Luck,
Wes
Bryan Cotton wrote:Mike,
I typically connected to the #4 plug wire. I prefer the right side because the starter is not in the way of the marks I made, as shown in the pictures earlier in the thread. I think I preferred the front cylinders because of ease of access for the inductive timing light pickup. But because my marks are arbitrary, and just meant to synchronize the primary to the secondary, any plug would do.
It doesn't make sense that your light won't fire for the secondary - unless maybe you have shielded spark plug wires. If so can you pull an unshielded wire from your junk box and put it in place temporarily? That won't change the timing at all, but may make the difference for the light.
I would expect the primary to have less spark energy so it seems backwards, but I believe in your observation.
mike.smith wrote:The wires from the coils are the ones that came with the AeroVee kit. I would think any modern electrical ignition wire would be shielded?
Users browsing this forum: Bing [Bot] and 4 guests
