Ercoupechris wrote:Sorry to say it but until someone comes up with a ring mount engine mount or rigid connection at engine and resilient isolators on the firewall, like most 912 engine installs are done, you will continue to be R&D
Skippydiesel wrote:I am seriously considering obtaining firmer rubbers - I know they are available.
What I don't know is, what the pros/cons may be in fitting firmer rubbers - what think you?
My Sonex Legacy has the thinner, than B model, bolts connecting the Sonex/Rotax adapter. There are 4 of these, in shear and they just don't "look" to be adequate. The reason I mention this, are my concerns that stiffer engine mounts may put additional pressure (vibration/twisting force) on these bolts - comments?
13brv3 wrote:I'm very glad I chose to use the ring mount. My only regrets are not adding some right thrust angle, and not using a softer damper. I used Lycoming sized conical dampers, and they're a bit too stiff.
