by karmarepair » Sat Dec 09, 2023 2:41 pm
Everybody that makes rattle-cans has a self etch primer. NAPA (Martin Senour), Rustoleum. They are all the same in performance. I keep a can handy, but rarely use it. I'm a slob about it too, and do no surface prep.
My view is that where you're based, you only need it as an undercoat for single pack top coat, but Navy carrier practice (well, they would do extensive, expensive surface prep first...) would be to put it on both surfaces of any faying joint, say, a lap in the wing skins, or at the rib to skin joint.
It's not clear to me that a single pack self etch primer will live under a two pack top coat. Stits and all the car paint people make two pack primers that are impervious to urethanes and pyroclastic flows.
If you WANT to go down a rabbit hole, there is a whole sub-forum on the Vans Air Force bulletin board about primers. It's one of those Christian/Muslim, Mac/Windows, Ford/Chevy divisive schisms, and I'm not exactly kidding.
Looks like a Portuguese barbecue joint within walking distance of Sky Acres! Gotta be the place!
