by Hap Hazard » Sat Dec 02, 2023 4:14 pm
Thanks guys for the answers to date. Pretty predictable spread out there on opinion, either side of the argument (depending on your view of course).
Firstly, my opinion is exactly that, (like yours) my opinion and I am obviously not an automotive design engineer, nor do I believe I know more than the guys at Sonex....
Firstly Karmarepair, thanks for the reply which introduces something that I hadnt really thought too much about in terms of wear. Most of the aftermarket pump covers I have seen on suppliers website are aluminium, so excessive wear is obviously not an immediate issue, or there would be a lot of comment all over the NET to steer away from them. Of course, an aluminium cover doesnt preclude the use of them per'se, oil pressure gauges give us a dynamic indication of oil pressure, so as the cover plate wear issues will no doubt result in less oil pressure. Ironically, I think particles suspended in the oil will probably cause more scratching/grooving and accelerated wear in the plates, so decent filtered oil becomes another good reason as to why you might want to consider filtering your oil! It is, nevertheless, a valid point that needs thinking about, so thank you for that.
What is more important to me as far as your post is concerned is the fact you can get pressure-relief cover plates. Reading up some more on these however, they sound like they dump oil back to the suction side of the pump(?). There are quite a few warnings out there that the relief valves have a tendency to stick and come with an engine health warning, so clearly they look like that they have their issues too and you run some pretty potentially high risks to your motor if this happens...so clearly more homework needed by ‘yours truly’ before I consider this route.
tps8903
Ok, in answer to your perfectly sound logic about VW Engineers...yes they knew their beans for the technology of the day, certainly without doubt, light-years beyond me. However, it is an old design, really old, as is many other aircraft motors out there that you mention, most of which were also designed in the 1930's. During the 60's and 70's there were some in-depth studies into the benefits of filtration and the results were clear. Since the lessons of those studies, ALL engines today are designed with far better oil filtration, with the proof of the VW pudding being that the Boffins at VW decided that the Type 4 was to have an oil filter fitted as standard.
So the longer term benefits are clear on that score (I have a conversion kit on my soon to be supercharged 1934 MG OHV engine, which also relied on a wire gauze filter). Neither am I questioning John Monnett's wisdom, but the fact he offers after-market kits in the form of the Maxi sump filter units, in itself means they consider it important enough to at least offer the option (my engine came with a brand-new Maxi-sump filter kit BTW, so that's an option open to me too). If that wasn’t enough, Revmaster (who IMHO made a more refined engineered engine) fitted their own proprietary high-volume oil pump bypass filter system, so again, another endorsement to giving the issue (on more than one level) very serious consideration, which in my opinion, backs up the fact that if you want to get the best out of an engine in terms of long-term reliability, then effective oil filtration is a no-brainer.
Also in answer to your other point…I think you have a typo, but I think I know what youre driving at…. If you are running the engine without an effective particulate oil filter, oil changes need to be MORE regular (not LESS as you state) if you want to ensure that levels of contamination remain as low as possible. No doubt that’s the main reason as to why Sonex recommend changing the oil every 25 hours, because they are working on the assumption that the vast majority of engine kits sold will never get a fine particle filter fitted(?). Trouble is regular oil changes do not stop metal particles from being transmitted around the system multiple times causing ongoing scoring of big-ends etc and the onset of premature wear…which brings me back to my point regarding long-term reliability…..
Bryan
Quote: “Also regarding adding flow with a 30mm pump - why?” Good point in which I hadn’t really explained the thinking, so my bad. Of course, volume and pressure are two different beasts. I have read (and indeed have been told by a VW shop) that one of the short-comings of the bolt-on, all-in-one pump/filters is that they do not pump as much volume as the conventional system as the oilways are restrictive(?). I made the statement for because I don’t know if the higher capacity pumps have bigger oilways, to and from the pump-cover, to filter? Of course Sonex push these engines out to 2100 CC so a bigger pump isn’t necessarily a bad idea, especially if introducing more restrictions in the system such as an Oil Filter, Oil Cooler, etc and you don’t want to drop main-bearing pressure, but the point still stands that Sonex have decided that the 26 mm gear is more than adequate (and more likely to take less energy from the engine to drive). As I haven’t seen one of the EMPI pumps in my hot little hand, I don’t know if they can be used with the standard Sonex 26mm pump that comes with the Aerovee kit? (I don’t see why not?).
So to summerise….
Area 51 is quite relaxed about his experiences with his oil-filter unit and indeed would fit another
Steel to aluminium wear of oil pump gears…worth considering, however I haven’t found any other references to accelerated wear issues on other forums etc. It suggests that it is not an issue that causes regular concern (and as Area 51 quite rightly points out, is operating in the best lubricated environment of the entire engine anyway)
Pressure relief valves in oil-pump covers, need more investigation (by me) as to where they by-pass excess oil pressure to. This may be as crucial to the integrity of the engine and warnings suggest that they could be as catastrophic to the engine as a blown gasket/filter. If this proves incorrect, a more conventional full-flow system (drilling the case) may be a better way to go despite the introduction of extra weight and complexity of introducing more pipe connections
That the benefits, as opposed to drawbacks, of particulate filtered oil is largely down to one’s personal opinion and understanding of what you are trying to achieve in terms of longevity/reliability of your engine and how you value the associated risks vs complexities
In terms of “whatever helps you sleep at night,” the minimum I would sleep with is, at worst, fitting the unused Mini-sump kit that came with the aircraft. At best, a better "spin-on" filter on the pressure outlet side of the pump…along with a properly set up and BALANCED bottom end (but that’s another story)….
