builderflyer wrote:Regarding toe in. The plans called for toe in is set with the aircraft in a level position. But for a tailwheel aircraft, the tires actually experience a minor toe out condition when the tailwheel is lowered to the ground. So if one only taxis and makes 3 point takeoffs and landings as I do, the tires never experience any wear brought about by a toe in condition. For the tailwheel aircraft, that would only occur if one raises the tail on takeoff or when making wheel landings. Just a thought that some may have not considered.
Art,,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,,Jabiru 3300 #261
Bryan Cotton wrote:I mostly do 3 point landings. I prefer to stand it on the mains for takeoff if the crosswind component is under 6kts or so. The aircraft does nice wheel landings. I don't think it is squirrelly on the mains at all.
Bryan Cotton wrote:Weight is the enemy! My latest Cheng Shin tire and tube weighed in at 3.16 lbs. My worn tire was 0.6+ lbs lighter.
Murray Parr wrote:Bryan Cotton wrote:Weight is the enemy! My latest Cheng Shin tire and tube weighed in at 3.16 lbs. My worn tire was 0.6+ lbs lighter.
If weight is the enemy, why don't you use worn out 0.6lbs lighter tires exclusively ;-)
Area 51% wrote:I had a similar issue. I had a machine shop relocate the mounting holes at the engine mount. This involved rotating the leg the required degree, and use a 5/16 bit. Then I bushed the hole back to 1/4.
I .
Users browsing this forum: Google Adsense [Bot] and 11 guests
