Bryan Cotton wrote:Can anyone tell me what the weight of the 5.00x5 tire and tube is?
Bryan Cotton wrote:I'll have to weigh one of my tubes. But the lightest 5.00x5 tyre I found in that chart was 4.9 lbs. I think by the time you add tubes that is a 5-6 lb weight increase. Hard pass for me!
builderflyer wrote:Bryan Cotton wrote:I'll have to weigh one of my tubes. But the lightest 5.00x5 tyre I found in that chart was 4.9 lbs. I think by the time you add tubes that is a 5-6 lb weight increase. Hard pass for me!
Bryan, I believe going to the larger 5.00x5 tires is probably the largest and most common mistake most builders make.. The weight penalty is severe, the cost penalty is outrageous, the braking action may even be reduced, and they're simply not needed on the Sonex. The smaller tires are perfectly adequate on the Sonex and if one keeps them inflated at 45-50 psi, they don't go flat.
Even Tony Spicer, who began flying his Sonex with the larger tires, eventually switched back to the smaller tires with success, and he was based on a grass field. Guess which tires I have on my Sonex.
Art,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,Jabiru 3300 #261
Users browsing this forum: No registered users and 29 guests
