Skippydiesel wrote:Just a thought: With pneumatic tyres, is there any benefit/problems with proactively filling with one of the leak fixes in a bottle? eg "Slime"
Murray Parr wrote:Skippydiesel wrote:Just a thought: With pneumatic tyres, is there any benefit/problems with proactively filling with one of the leak fixes in a bottle? eg "Slime"
A bit of extra weight and potentially out of balance comes to mind.
Could potentially mitigate the out of balance if you could run the wheels up to speed before it sets.
peter anson wrote:Skippydiesel wrote:Just a thought: With pneumatic tyres, is there any benefit/problems with proactively filling with one of the leak fixes in a bottle? eg "Slime"
My experience with "Slime" is all on off-road motorcycles. I have heard that it can work with thorn punctures which are a real danger in some parts of Australia, however if it doesn't work, the only repair is a new tube. You can't patch a tube with that stuff oozing out. I have had several punctures in main tyres as well as one tail wheel puncture. All of the punctures have been in side walls which probably indicate that I am running the pressures a bit low. I have never had the tyre turn on the rim but the holes have all been tiny splits in the rubber which I guess have been caused by the side wall flexing too much. The tail wheel puncture was definitely from running too low a pressure but I wasn't carrying a pump at the time so couldn't correct it. I always carry spare tubes when touring.
Users browsing this forum: No registered users and 41 guests
