Crankshaft failure in flight, lost propeller, no injuries
Re: Crankshaft failure in flight, lost propeller, no injurie
Postby Dave Wolfe » Thu Nov 16, 2023 11:21 am
Congrats on a safe outcome!
How many hours were on the engine?
The 2.1 crankshaft and hub use a smaller diameter bolt so crankshaft failure is less likely. Failures originate with cracks between the keyway and inner diameter of the prop hub main bolt.
This page shows the two different crankshafts:
https://onex-svingenb.blogspot.com/p/pr ... s.html?m=1
Dave Wolfe
Postby jerryhain » Thu Nov 16, 2023 12:10 pm
As a flight instructor, I would like to congratulate you on maintaining your cool and keeping your situational awareness. Very few pilots get to experience a true emergency. Out of curiosity, do you happen to be a glider pilot as well?
Jerry Hain, Tucson AZ
Waiex Electric?
CFI Glider/Airplane/Helicopter A&P
jerryhain
Postby peter anson » Thu Nov 16, 2023 7:32 pm
jerryhain wrote:Out of curiosity, do you happen to be a glider pilot as well?
If he wasn't before, he is now.
Congratulations on getting down safely in what was obviously challenging conditions.
peter anson
Postby tps8903 » Thu Nov 16, 2023 10:43 pm
Involuntary glider pilot life achievement unlocked.
Chris Morris
Sonex N998PC - SOLD!
Sonex #1732 - Aerovee Turbo
Central Florida
tps8903
Postby Weatherpilot » Thu Nov 16, 2023 11:05 pm
Nice job getting her down. Any idea where the prop/spinner/crank ended up?
Again - great aviating. My hat's off to you.
Greg.
Greg Hubert
Sonex A #972 TD
Aerovee Prince P-Tip / Dual stick
Third Owner
Eastern Panhandle of West Virginia
Weatherpilot
Postby karmarepair » Fri Nov 17, 2023 12:54 am
Please take pictures of the fracture surface of what's left of the crank, both from a bit of a distance, and from as close as possible. The fine scale details of the fracture surface can tell a LOT about how the failure started.
karmarepair
Users browsing this forum: No registered users and 54 guests
