DCASonex wrote:Thanks for the photo. I would remove your fuel level sensor just to make sure it does not get damaged....
DCASonex wrote:...
Re-reading the previous post of yours, it might not have been clear that you do not need to remove the mound of plastic that used to surround the molded in fitting, just flatten the inside surface enough to give the O-ring a surface to seal on. If the oops fitting is not long enough to put on a fiber washer and thread the nut the on outside, then you will have to grind it down a bit.
