by tps8903 » Tue Nov 14, 2023 6:10 pm
I have had two problems that mimic your current situation that I have fixed.
First was the fuel line vapor lock. I got it while taxiing in on my Turbo engine after long flights or on hot days.
My fix:
Removed gascolator and Fuel flow transducer. Both were aft of the firewall and acted like heat sinks. I also made the fuel line direct, like 14" total then wrapped that in the metal flexible heat wrap, then wrapped it again in the gold foil wrap. Problem #1 solved.
My second issue was a bad magneto, and then a bad coil. Heat damaged 3 of 4 of my ignition moduals over a 1 month period. I eventually replaced them all and changed the cooling to the back of the cowl which has remedied that situation. You can see if it's the mags by switching them off in flight one at a time.
Chris Morris
Sonex N998PC - SOLD!
Sonex #1732 - Aerovee Turbo
Central Florida
