by BenCharvet » Mon Nov 13, 2023 12:09 pm
I've had a problem recently where my Jab will quit 3/4 of the time when turning right off of the runway. It gives no warning, and immediately restarts. I've tried leaving it leaned, and full rich. My setup has no gascolator or fuel drains, all fuel lines are insulated, air deflector for the oil cooler, and exhaust pipes are wrappped. I'm in Florida, and I still get occasional burps on takeoff if I have a long taxi and its hot out. I've tried increasing RPM to 12-1300 prior to turning and it still happens like 3/4 of the time. Last week I noticed a stumble as I turned right to get on the runway. I haven't noticed any problems with left turns on the ground, and after its in the air everything is fine. I have an e-mag from Rotec on the right, wired completely separate from the original mag on the left, so I doubt it is that. There is no wiring anywhere near the rudder pedals or the rudder linkage FWF. Any ideas?
