lakespookie wrote:Keep in mind with the aerovee there are some additional maintenance items like valve adjustment that needs to be done at every oil change etc. but operating cost are way lower,
The advantage to building is the repairman certificate and customization of the platform.
jklPDXPilot wrote:Hi,
I'm a new member of this community and am considering building either a Onex or Sonex
Thanks a bunch!
James
Scott Todd wrote:... Buy one already flying. If you fall in love with it, then build one or buy a project to finish....
BenCharvet wrote:If your BIL was once an A/P he still is, unless it was revoked. The AP doesn't require renewal. That means if he is willing you could do the condition inspections together.
tps8903 wrote:You only need the mechanic to sign off the annual condition inspection. You can do all the work, including engine work, and most of, if not all of the condition inspection. It will depend on your and your A&P comfort level. For homebuilt the A&P dosent require an IA
jklPDXPilot wrote:
I've been looking at used Sonnex's and the prices look good. I think I would want one that is flying regularly and still spend some time going through it myself, but it does look like a substantial $ savings.
