Cracked tailwheel bracket
Postby Bryan Cotton » Sat Oct 21, 2023 6:57 pm
We were flying patterns today and started getting a noise from the tailwheel. Knocked it off and discovered this crack. The tailwheel bracket was noticably bent.
cracked tw bracket on airplane.png (624.37 KiB) Viewed 1794 times
Powdercoat stripped off:
cracks after powder coat removal.png (467.91 KiB) Viewed 1794 times
I welded it back up, and welded on some doublers as well.
painted reinforced bracket.png (470.1 KiB) Viewed 1794 times
Edit: the smaller cracks were hidden by the powdercoat. The noise was the pivot bolt head dragging on the ground. The noise started off just when we hit a bump, then got more steady.
Re: Cracked tailwheel bracket
Postby tps8903 » Sat Oct 21, 2023 8:00 pm
Good catch!
Chris Morris
Sonex N998PC - SOLD!
Sonex #1732 - Aerovee Turbo
Central Florida
tps8903
Postby Tony4aro » Sun Oct 22, 2023 7:16 am
Glad you found it before it broke away completely.
Corvair powered Waiex (under construction)
N3848D
W0181
Tony4aro
Users browsing this forum: Tony4aro and 69 guests
