rpf wrote:H Rusty,
I've decided to make my own gear. I purchased a piece of 7075 flat stock (5inches wide x 5/8 inches thick and 96 inches long). I'm going to make the gear about 3 inches taller and in doing so will be slightly wider also. My friend has a hydraulic press, and we will lay it all out, cut the angles and radius all the edges before we bend.
rpf wrote:H Rusty,
rpf wrote:I've decided to make my own gear. I purchased a piece of 7075 flat stock (5inches wide x 5/8 inches thick and 96 inches long). I'm going to make the gear about 3 inches taller and in doing so will be slightly wider also. My friend has a hydraulic press, and we will lay it all out, cut the angles and radius all the edges before we bend.
peter anson wrote:rpf wrote:I've decided to make my own gear. I purchased a piece of 7075 flat stock (5inches wide x 5/8 inches thick and 96 inches long). I'm going to make the gear about 3 inches taller and in doing so will be slightly wider also. My friend has a hydraulic press, and we will lay it all out, cut the angles and radius all the edges before we bend.
I don't know how sharp the bends in the Onex gear are but the best method for making these would be to bend them with the metal in a soft condition and then have them age hardened. To do that you need to get the material solution treated - heated to about 500°C for a time and then quenched. After quenching the metal will be soft but returns to a fairly hard condition within a couple of hours at room temperature but you can delay it by keeping it cold, like packed in dry ice cold, until you are able to form it to the shape you want. The final step is age hardening, heating the formed parts to around 180°C for around 12 hours. All those temperatures and times are just guesses but the information is available in spec sheets. You should end up with parts that are high strength without inbuilt stresses. I know that may seem like a lot of trouble but I would guess that's how the original parts are made. It would probably be best to get the parts anodized too because 7075 is not corrosion resistant.
tps8903 wrote:
Would it be easier to buy the bar stock annealed as 7075-0 and then bend and heat treat to T6?
Users browsing this forum: Bing [Bot] and 44 guests
