Bryan Cotton wrote:I must have gotten lucky. My battery shows 13.2V during runup and 14.5-14.6 in cruise. Stock VR that came with my Aerovee kit.
I have pretty minimal electric loads. I turn off the secondary ignition out of the pattern.
tps8903 wrote:Bryan Cotton wrote:I must have gotten lucky. My battery shows 13.2V during runup and 14.5-14.6 in cruise. Stock VR that came with my Aerovee kit.
I thought about this after I ordered the other one. I'm wondering if the load is dragging the voltage down. I guess tomorrow I'll have to find out. I'll unload and turn off the lights and electric Ignition and see what it does. I think it's low regardless, I usually start with 12.8V and then It stabilizes at 13.2V in cruise.
Bryan,
Thank you for contacting us with that question. At the present time, we do not have a voltage regulator that we consider compatible with the AeroVee alternator. We have a design in the development process that should be suitable, however. I have not been given a release date at this point, but if all goes well with tests of the prototypes, it may be available within the next 6 months or so.
We appreciate your checking with us. Please let me know if you have any other questions.
Kind Regards,
“TJ” Jenkins
B&C Specialty Products
123 E. 4th Street
Newton, KS 67114 USA
Voice: 316-283-8000
daleandee wrote:
Wires are as follows:
blue wires (2) are AC voltage from the PMA
the red wire (1) is charging voltage to the battery
black wire (1) is ground
yellow wire (1) is the sense wire & turns on the regulator
green wire (1) idiot light - generally not used
Dale
3.0 Corvair/Tailwheel
daleandee wrote:Bryan ... good deal! Just a few thoughts,
I cut the original plug off the regulator and used some high quality faston terminals as some folks complained about the original connectors not holding up very well.
Also on the other thread you noted that you spaced it away from the firewall. I did that initally but someone smarter than me suggested that I mount it to the firewall and recommended to use heat sink compound so that the regulator could use the firewall as a heat sink. BTW, I have a small blast tube on mine with a a small cover that directs the air through the fins.
As an aside, some even suggest to mount the fins vertically so the rising heat can better disipate. How much difference any of this really makes is unknown to me. As they say ... you pay your money and takes your chances.
Any idea whether you can make the KJZP fly-in (if it happens of course)?
Dale
Dale
