Murray Parr wrote:I am now thinking I might have to align the engine with a few degrees of right thrust built in unless anyone else can suggest further adjustments I could try.
Onex107 wrote:I don't know anything about the "V" tail but I'll throw this in. I presume your rudders are hinged the same as the Onex, on one side. I added a simple gap seal to my rudder and elevators and saw a significant difference in the hands off cruise. Just sayin.
bvolcko38 wrote:Have you ever seen a Ercoupe with the cowling off? Huge amounts of right and down thrust built into the motor mounts. Sounds like you might need some right thrust to counteract some minute amount of twist in your empannage.
JMHO
bvolcko38 wrote:Yes, I agree, if the yaw goes away when you reduce power, it seems to be an engine thrust problem.
