BRS wrote:If it's not been run in 10 yrs and you did a dry compression reading I would expect poor results.
If running the engine as suggested doesn’t help, then check the (Rhino) rocker gear is not contacting the inside of the rocker cover and holding a valve open. This can occur if a cork gasket has been reused and compressed thereby reducing clearance
Weatherpilot wrote:If running the engine as suggested doesn’t help, then check the (Rhino) rocker gear is not contacting the inside of the rocker cover and holding a valve open. This can occur if a cork gasket has been reused and compressed thereby reducing clearance
Purchased some new rocker covers and corks from EMPI just in case. The original covers are definitely compressed and were RTV'd on so I just bought a new kit with corks and covers for less than $50 online.
Thanks for the suggestion.
