gammaxy wrote:vernd wrote:So for those of you who have drilled out the attach blocks with 3/8 bit and used AN6 bolt or trailer hitch pin – have you been happy with the fit? I’ve heard comments about having to lightly “tap” the bolt or pin into place after drilling.
I used the Fastenal bit I linked to earlier in this thread (sounds like the same one you are using). Unfortunately, I don't remember the diameter I measured for the AN6 bolt. My experience was the same as Corby202--only had to tap the bolts in when installing on the airplane.
I occasionally shake the airplane by the wingtip to see if there's any looseness and I haven't noticed any.
Bryan Cotton wrote:Can you get a buddy with a lathe to turn down the drill? Would probably need to grind it down a little.
Area 51% wrote:Have you considered an under-sized drill bit then using a reamer to get the fit you need?
yx0020 wrote:Bryan Cotton wrote:Can you get a buddy with a lathe to turn down the drill? Would probably need to grind it down a little.
I do not have a buddy like that but I can try holding a sanding block against the side of a bit rotating in a drill press...
yx0020 wrote:Area 51% wrote:Have you considered an under-sized drill bit then using a reamer to get the fit you need?
It sounds like pretty much everybody recommends using piloted drill bit while drilling assembled wings. I do not think I will be able to find an under-sized bit like that.
