Hi all,
I'm seriously considering purchasing a used Legacy SONEX. To that end, I'm trying to work out a W&B profile for ForeFlight and I'm sorta at a loss.
W&B info for the airplaneEmpty Weight & CG
Left Wheel WT: 216lb ARM: 78.5" MOMENT: 16956
Right Wheel WT: 255lb ARM: 78.5" MOMENT: 20017
Nose Wheel WT: 176lb ARM: 26.5" MOMENT: 4664
Empty Weight: 647lb
Empty CG: 64.3"
Most Aft Weight & CG
Aircraft Empty = 647lb Arm: 41637
Front Seat = WT: 170lb ARM: 91" MOMENT: 15470
Bagage = WT: 0lbs ARM: 105" MOMENT: 0
Fuel = WT: 60lbs ARM: 47" MOMENT: 2820
Weight = 879lb MOMENT: 59927
CG = 68.3"
Most Forward Weight & CG
Front Seat = WT: 340lb ARM: 91" MOMENT: 30940
Fuel = WT: 80lbs ARM: 47" MOMENT: 3760
Weight = 1067lb MOMENT: 76377
CG = 71.5"
Does anyone have ForeFlight W&B numbers I can plug in for Forward / Aft CG limits and the station arms for the cockpit seat, baggage station and fuel tank? I have tried doing this myself but, I'm ending up with a max TOW of 960lbs (16gals + 310lbs PAX) to stay in balance. Anything over 310lbs of PAX puts it out of balance with AFT CG. I've obviously got something wrong because I can't imaging SONEX approving 1150lbs Max Gross (JAB3300 engine) if it threw CG so far AFT.
Here is what I have in ForeFlight. I'm obviously doing this wrong.
BEW CG: 64.3"
BEW: 650lbs
Stations: Pilot = 91" Baggage = 105" Fuel = 47"
Forward CG Limits:
64.3" 675lbs
64.3" 1100lbs
64.3" 1150lbs
AFT CG Limits:
68.5" 1150lbs
70.25" 1075lbs
71.5" 675lbs
71.5" 1025lbs
Thanks for your help!
John
