Panther16 wrote:On the Sonex the D180 haas 2 inputs for the tach. I take 1 off the left mag and the other off the Jabiru alternator.
On the Panther I have GRT 6 cylinder EIS and take the tach signal off the rear mounted SPA alternator.
Panther16 wrote:As for tach may need a resistor in line, should be in instructions for instrument you are using. You have 50% chance of picking correct output lead of alternator, only 1 will work. If it doesn’t work switch to other output lead.
Users browsing this forum: No registered users and 22 guests
