Bryan Cotton wrote:On the ground, my stick will pretty much move full range when I crank my trim.
Panther16 wrote:Every thing you put in the a/c along with fuel burn moves the the cg aft. 4 turns up gives 70 on final and any from 3 -4 turns in cruise depending on speed. I suspect you may have the same issue if are using a corvair and don’t add some weight in the tail.
Panther16 wrote:I don’t think you need to worry about the trim until you do the weight and balance and find out where the cg is. I originally built my Sonex with the Aerrovee. After 80 hrs I converted to aJab 3300 due to performance issues. With the 3300 my cg is close to the fwd limit, about the base of the instrument panel. My dial a trim is adjusted so the elevator is about 1 in up from neutral at full nose down on the dial. Every thing you put in the a/c along with fuel burn moves the the cg aft. 4 turns up gives 70 on final and any from 3 -4 turns in cruise depending on speed. I suspect you may have the same issue if are using a corvair and don’t add some weight in the tail.
The only issue with the way it is adjusted is on a go around you need to take out 2 turns otherwise the stick force gets very hi holding the nose down.
Keith Rhode
Sonex 214KE
Bryan Cotton wrote:I agree that CG is a big effect on trim. Also here is a picture of the knob I put on my dial-a-trim.
