by James Wiebe » Mon Aug 07, 2023 8:42 pm
Hi Everyone!
I just purchased a Sonex TD, and I just finished my first cross country, 2:20 in length.
Super fun bird to fly.... nice and fast.... but I've got a problem with oil consumption.
The prior owner had no issues with oil consumption; the engine is a 2.1 with a top oil cooler upgrade. It does not have an oil filter.
The plane has zero oil leaks, at least to the visible eye.
The engine has <600 hours and was rebuilt to a 2.1 about 4 years ago. In that time, it's logged another <200 hours with zero issues with prior owners.
Anyway, on my cross country flight, it apparently drank more than a quart of oil. Very shortly before touchdown, I encountered dipping oil pressure; thankfully I was on the ground just a few minutes later.
Before the flight, the prior owner and I both checked that oil was full.
After the flight, the oil was below the lowest notch on the oil dipstick. Adding a quart raised it to mid marks, and the oil pressure issue disappeared on a ground test run.
I need help, that's for sure. I'm in the middle of a cross country ferry flight home.
Oh yeah, I was running 3300 RPM with around 1220 on the EGTs and low 300's on the CHT. The flight was a little bumpy, but I've had far worse over my flying career.
After landing and parking the plane, there is no significant oil residue on the underside, and only a couple spots of oil out of the breather.
Last compressions were excellent, high 70's.
Thanks!
James Wiebe
