sight picture (over the nose)
Re: sight picture (over the nose)
Postby Skippydiesel » Thu Aug 03, 2023 7:12 pm
I am reliably informed, that most Sonex cruise, with about 1.5 degrees nose up attitude.
Skippydiesel
Postby Kai » Fri Aug 04, 2023 1:50 am
Would´nt that depend of the airspeed you decide to cruise? The faster you go, the lower the aoa to keep the needle of the vsi on zero?
Sonex A #0525- SG, DS.
Kai
Postby XenosN42 » Fri Aug 04, 2023 8:08 am
Skippydiesel wrote:I am reliably informed, that most Sonex cruise, with about 1.5 degrees nose up attitude.
Please site source. Thanks.
-- Michael
OneX N169XE
XenosN42
Postby Skippydiesel » Sun Aug 06, 2023 3:54 am
Won't use his name (without permission), however Sonex plans builder & very experienced pilot in a wide range of piston aircraft (including Ag & airobats) who flew in a number of Sonex and went to the trouble of making some inflight measurements and found a consistent 1.5 degree nose up.
Skippydiesel
Postby gammaxy » Sun Aug 06, 2023 11:16 pm
This is typical of what I see in slow cruise with the Aerovee.
In comparing the images, it's clear that my eye level is significantly higher.
Out of curiosity, I measured my pitch angle using the longeron as reference as 3.5 degrees at about 110-120mph at about 900lbs and about 3000ft density altitude.
Postby sonex892. » Mon Aug 07, 2023 11:17 pm
Photos of the sight picture and relative angle of the longeron with the horizon taken doing 122kts this morning. To my eyes the longeron looks to be level with the horizon.
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby Bryan Cotton » Sun Aug 13, 2023 6:53 pm
A couple of years ago I had made hard pink foam boosters that went over each side of the seat sling. They often broke in front, and also reduced stick motion because of interference with my legs from being higher. I've backed off the fronts, from about a half inch aft of the sticks. Seems better and I'll do a flight report when I get a chance. Each side has two layers so you can get a half or full inch boost.
Postby BRS » Sun Aug 13, 2023 7:34 pm
Since my first post I did go up and take a closer look as well as bring up a digital level. As I recall, the level showed 3.3 - 3.4 deg and actually my nose was lower when straight and level than I thought, at least below the horizon.
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Postby Bryan Cotton » Tue Aug 15, 2023 2:13 pm
Here are my foam boosters. They are cut and glued to match the seat pan bend. The top one is cut back further from the stick. Thickness is 9/16" each piece, so 1.125" total.
foam boosters.png (536.26 KiB) Viewed 7051 times
Postby BRS » Tue Aug 15, 2023 7:34 pm
Bryan Cotton wrote:Here are my foam boosters. They are cut and glued to match the seat pan bend. The top one is cut back further from the stick. Thickness is 9/16" each piece, so 1.125" total.
Well that looks simple enough. I'll have to check my head clearance and see about a booster seat. Either that or a back-stretcher.
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
