by pappas » Wed Aug 09, 2023 1:46 pm
I only use AVGas in my aircraft and live in the Phoenix, AZ area. Very dry here. Since moving here I have never had issues with water in my fuel. The instructions from RED/Princeton recommend that you do not use water to calibrate the probe as it will give you different readings than fuel. So, just calibrate it with fuel. If it gets wet from water, just make sure it is completely dry prior to calibrating with fuel.
Remember that water is heavier than fuel and will seek the lowest point in your fuel system. If you have a gascolator water will settle there and you will drain it prior to flight. I did not use a gascolator in either of my Sonex's and had no issues with the Aeroinjector passing any water that may have been there, ( I never noticed any).
The probe needed to be cut and shortened a bit in order to fit in the B model tank according to the plans. I don't remember if it needed to be cut for the Legacy model. Cutting and calibrating was no problem, I simply followed the written instructions and all went as expected. I also used the same model probe in my first Waiex, a legacy model, with no problems whatsoever. I would use it again without concern.
Coincidentally, the RV7-A I am building has the Van's capacitive plates in the tanks and the sending unit that we use for those is also the Princeton/RED modules. I like having the capacitive measuring devices but still rely mostly on a calibrated fuel flow sender for the most accurate indication of remaining fuel and flight times.
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
