Chatterton wrote:Engine is momentarily - one or two seconds at a time - cutting out on climb out at about 100 feet - i.e. after several seconds. I back off power and it clears after 30 seconds or so and then runs normally, but it is a long 30 seconds ! Only happens on initial take off, not on a go around. Full throttle runs before take off are normal and I can't replicate the problem on the ground.
New manual pump fitted, and now electric back up with pressure regulator.
Any advice / bright ideas, please ? Rob Chat.
Unfortunately all the smart people are at AV so I'll chime in and see if I can give some sage advice.
My best advice is not to fly the thing until you get it fixed. I know you said the problem won't appear on the ground but flying an aircraft with a known deficiency is not only illegal, it is unwise (read stupid) and could get you killed. Not trying to be harsh but rather to keep you alive. Your report that it doesn't do it on a go-around suggest that it is likely a problem related to too much heat under the cowling.
What carb do you have? If it is an Aerocarb (now called an Aero Injector) they are world famous (as are most all slide type carbs) for stumbles and burps because of vapor lock and air bubbles in the fuel line that go through the carb instead of out a vent as on a float bowl carb. Some pilots live with these burps but personally I wouldn't and I don't. The vehicle I drive to the airport on the ground don't do that so it is not acceptable to me that my airplane do it.
Heat shielding all the fuel lines & the gascolator (some suggest to remove it but I disagree) and adding a cooling blast tube to the gascolator can help. Rerouting fuel lines away from heat sources can also help.
Also be aware that if you are using a slide carb they do not like much fuel pressure and/or ram air induction.
Perhaps you can give some more details as to what the CHT's, EGT's, and fuel flow look like before, during, and after these events. What is your fuel pressure reading?
Keep in mind that this is occurring with the nose up while climbing. Have you done a gravity fuel flow test and made certain that there are no obstructions to fuel flow at high angles of attack?
Hope you get this resolved because there is not much worse than flying a plane you can't trust. Been there, got the T-shirt & the mug ...
