13brv3 wrote:I've used several EarthX batteries........................................................................................
As for fuel pumps, I've been using these for years, particularly now with the Onex since it has that "fuel through your windscreen" feature. The only problem I've had with them is the AA battery contacts. They corrode constantly, even with dielectric grease on them. I'll likely end up modifying mine with an external plug for the battery connection.
I can't imagine carrying anything in the plane used for fueling though. That would have to stink. I only fly locally, so 100% of my fueling is done at my hangar.
Cheers,
Rusty
Hi Rusty - When I decided I had become sufficiently mature (decrepit) I thoroughly researches the market place for petrol (not diesel or other fluids) refuelling pumps/systems, that would not be dependent on muscle power (lifting 20 L above waist high). I was looking for a pump that would run of ship (12v) or hand power, deliver 20 litres in 3-5 minutes from a 20 litre rigid or flexible bladder, lift fuel, from ground level, into a high wing tank, portable (in aircraft baggage area) be cost effective and flash/ignition resistant.
From failing memory - the pumps fell into the following categories;
Hand operated positive displacement vain pumps; All that would deliver required rate, way to large & heavy. Unable to pump from a fuel bladder (not enough hands).
Electrically (12V-240V) powered positive displacement vain pumps. 240V units disqualified - impractical when away on trip. 12V units very few offerings, heavy & expensive.
Smaller 12V units as used in light aircraft transfer/boost duty - low delivery rate well below what I was looking for.
Gimmick offerings - Sorry Rusty could not think of a other word to describe what I see as slightly enhanced syphons. Siphons are great example of the KISS philosophy (I have several simple ones for tractor & mower applications) but they are only useful when the fuel level is above the delivery point.
Everything that looked the part was only suitable for diesel, kerosene, etc.
After a long and disappointing search I happened on the Holly (carburettors/fuel systems) web site and found a petrol transfer pump designed for very high performance race vehicles. Met all of my specifications except for a price (in Australia) of about $500Au. Looked a little further, the Chines have a copy (almost identical appearance & performance) for under $80Au. A bit of fuel hose, a "spike" (repurposed irrigation riser) suitable switch, cable, Anderson Plug connector (to ship power) and alligator clamp earth. I have a pump which has been doing excellent service for about 6 years now. I can hold the switch on/off in one hand, the fuel hose in the other and the pump sits securely in the neck of the fuel drum/bladder (curtesy of the spike).
As for fuel smell in cockpit - make sure pump is completely empty of fuel/dry - plug inlet/outlet will eliminate almost all odour. I also carry 20L x 2 fuel bladders for collecting ULP when on a trip - don't notice any smell from them either.
