Bryan Cotton wrote:I think this is the relevant fault from the EarthX manual:
XenosN42 wrote:Are you using the correct EarthX battery charger to maintain the battery between flights?
Bryan Cotton wrote: I have an Optimate charger - the recommended one.
daleandee wrote:I could be wrong here (wouldn't be the first time) but it appears your charging voltage is too low for the battery.
13brv3 wrote:I've never heard of any requirement, or even recommendation to use the special charger between flights. I probably haven't attached mine in over a year. It's probably not a bad idea to use it periodically, but it's certainly not needed between every flight.
Users browsing this forum: Google [Bot] and 18 guests
